Bending Figured Claro Walnut
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=4639
Author:  peterm [ Fri Jan 20, 2006 2:03 pm ]
I just read the tread on bending Koa and I am about to bend a set of high figure walnut....my first set of walnut. Is there anything I should watch for before I bend? Temp?
peterm38737.9219907407
Author:  Brock Poling [ Fri Jan 20, 2006 2:07 pm ]
The stuff bends like plastic. Walnut is very forgiving.
Any high curl woods can be a challenge, but walnut is about as easy as they come.
Author:  BlueSpirit [ Fri Jan 20, 2006 5:53 pm ]
I like to bend Walnut. It's pretty forgiving, but Brock is correct about curl.
Author:  tippie53 [ Fri Jan 20, 2006 10:37 pm ]
    If you are using the machine , the bending technique is the same as for figured Koa . If you are bending by hand the use of a flexible plate over the iron helps to keep the figure from potato chipping
john hall
